HELP NEEDED no2!!!!!
- jamieclayton9
Hi all. when i am driving my xsara 1.9td 1998 every now and then i get the stop light on the dash come up and the light on the tempruture guage. i assume that its to say the car is over heating but it is not. it can even come on just after i start the car. any idea what it could be. many thanks. jamie
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
Re: HELP NEEDED no2!!!!!
No! ------------------ But when you find out, let me know. My daughter's Xsara does the same thing. Presumably it's a dodgy connector some where.jamieclayton9 wrote: any idea what it could be. jamie
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
- CitroJim
- x 6160
- Contact:
The overtemperature light is usually on its own sensor on the thermostat housing. It'll most likely be dodgy connections. I cannot recall off hand what sensor it is but it'll be one with just one connection even though it will have a two pin plug on it.
The lamp needs an earth to light so the problem may be a bit of dirt and corrosion has got in (a bit of coolant maybe?) to the sensor connector.
You get the same lights on a 1.9 td Xantia. In that case it's caused by the Bitron unit which controls the cooling fans etc.
The Bitron is supplied by a brown coloured temperature sensor which is mounted on the fuel filter base.
Now, I don't know if your Xsara has a Bitron unit but if it does, the problem is usually a build up of oxidation on the brown electrical connector on the temp sensor. Just pull it off and push it back on a few times and it will probably cure the problem.
good luck,
Kev
good luck,
Kev
Cheers, Kev
In addition to that, the Bitron pins are tinned with solder, and in time the contacts become dodgy, most obviously pins 7 & 14 that have the resistive brown sensor input.
I had this problem, and cured it by scraping the Bitron pins with the rough end of a piece of broken metals hacksaw blade.
A previous squirt of WD40 on the Bitron pins was good for only a few days.
Citroën in France made free out-of-warranty brown-sensing modifications back then.
It wasn’t a recall, or correction, or modification ... it was an evolution:
http://xu10j4r.free.fr/xantia/notexantia.pdf
2002 C5 2.0i AL4 230,000 km 76372389
- jamieclayton9
- jamieclayton9
