Can someone with access to pr-net give me the part numbers for a couple of parts for a '97 TD SX.A crankshaft pulley bolt and the O ring in the bottom hose to radiator bayonet connection.
Many thanks,
Oldnail.
PR-NET
'97 TD, OPR-7695, a/c ???
O ring in the bottom hose to radiator bayonet connection :
DIESEL TURBO XUD9TE ET REFRIGERATION DEPUIS OPR 07483
(- TURBO DIESEL XUD9TE AND AIR CONDITIONING SINCE RPO No. 07483)
1343.Z4 END-PIEC GASKET - TURBO DIESEL XUD9TE AND AIR CONDITIONING (approx £1)
crankshaft pulley bolt (all models) :
0516.A4 PULLEY SCREW (approx £3)
NOTE : Part no's valid at your nearest Peugeot dealer as well.
Anders (DK) - '90 BX16Image
PR-NET
Thanks Anders,
Appears I've been given the correct bolt but wrong O ring.
On the invoice the O ring part number is C133994.It looks much to small to me as it measures 22mm ODx19mm ID.
I wanted to get a new one before I removed the bottom hose to drain coolant so have not got the old one to compare.
My cars non A/C.
oldnail
My cars non A/C.
oldnail
