Strange 'scraping' noise
Over the last week my beloved Xantia has started making what I can only describe as a scraping noise when I brake, sometimes the noise continues when I move off and then disappears. My brakes are fairly new (3 months old). I had two new front tyres fitted 3 weeks a go. I dont know if this noise could be caused by sticking brakes or something, but the car is running fine. Any ideas before I put it in for a check would be appreciated. Thanks. Tony
Xantia 1.9 TD LX 1994 - 152,000 miles and running, strange vibrations
Scraping brake sounds usually emanate from the back as there are no sensor wires. The first you know is the scraping sound which is usually metal on metal.
Happened to my XM a couple of years ago. Fortunately I had a set of pads here as someone had given me a set of CX rears which are the same for an XM. I changed them one morning before going to work. Each side took about 25 mins. Read your Haynes BOFT first.
Otherwise I would suggest blasting built up brake dust out of the front brakes with a garden hose or pressure wash. Although front brake dust build up is usually squeally not scrapy. Very technical eh?
Craig Keller
Gerringong
Australia
"A little dab of LHM goes a long way!"
Gerringong
Australia
have you visualy checked the front brakes,just because they were done about 3 months ago dose not mean they are not worn out again already,if the cable/s or the caliper is are sticking it will wear them out very quicke,the usual with citroens with hand brake at the front is binding cables as the crack were the cable is constanly flexed as you turn the steering,so they get water and grit in the cable
regards malcolm
regards malcolm
You are spot on UFO. The rears are down to the metal. Because it sounded like the front when driving, and I thought the rears would last longer than the car, I didn't look there I'll be doing them tomorrow, thanks again!UFO wrote:Scraping brake sounds usually emanate from the back as there are no sensor wires. The first you know is the scraping sound which is usually metal on metal. Happened to my XM a couple of years ago. Fortunately I had a set of pads here as someone had given me a set of CX rears which are the same for an XM. I changed them one morning before going to work. Each side took about 25 mins.
Hi there.. isn't it good when there is a simple fix ? BTW.. Citroen sell a kit for the rear brakes on a xant consisting of the nuts and bolts, the cover plates and springs (for both sides) this only costs a few pounds and makes a good job an easier one ! And as johnd says its worth checking for corrosion build up between the caliper and arm while you're at it. Bets wishes, Martin
I won't do that again
