Hi, I need a RH electric door miror for a '96 18i 16v Xantia, silver. Someone has snapped sister-in-laws off over night - Malcolm, can you.......
Disappointing to have to fork out for someone elses vandalism whatever. New one not being painted is a pain. Anyone know of a breaker / second-hand parts dealer who may have a silver one?
Cheers
Xantia Door Mirror
Xantia Door Mirror
Malcolm
'98 Xantia Estate LX - RIP 13/08/16
'08 Renault Trafic 115dci
iv'e had both side done as someone kindly smashed both sided off, i now fold one side in, and have repaired the other side but cant fold it in.
Mine are colour coded but green, however the colour coded panel just unclips off so you can change the colour-coded panel around, or they do on mine.
Are you sure the mirror cant be repaired, normally a few screws to connect the mirror to the triangular shaped black panel should hold it together, although you cant fold the mirror in using this method.
If you want 2nd hand one try ebay.
currently no citroens
1.4 2000 forte now gone too
xantia 1.8i 16v dimension 1996P now gone,
Hi, thanks for reply. I've not seen her car since it was damaged. I was wondering if the colour bit would clip off, which you have now confirmed. The suggested repair sounds good, I'll have to get down and see if something like that is possible. Thanks again, Malcolm
p.s. yes I've looked on ebay - no 2nd hand. I've emailed a couple of previous 2nd hand suppliers - no joy
Malcolm
