I've a '94 petrol Xantia that's done 178k miles.
The heater matrix seems fine.
What's the best way to keep it like that, regular flushing, high anti-freeze concentration etc.,?
Or is it just pot-luck?
Heater Matrix NOT Leaking.
thats exactly were mine went, i've done a few heater matrix's before but not on a cit and all of the others i've done the core had rotted away so i was amazed to find that the core was solid and that it was leaking from the o rings in the inlet joint, 10hrs work for a couple of leaky o ringsDave Burns wrote:Of those I've done so far, none of the actual metal matrix has failed, its allways been the bloody O rings between the matrix and its plastic inlet, these bits are screwed together, they ought to be a one piece moulding but this is Citroen so it aint.
Dave
as i said earlyer i belive its down to the car running to hot for what ever reason,usualy rad fans not kicking in when they are ment to,most of the heater matrix i have replaced on citroens are leaking because the plastic end/s have come away frome the tubes of the matrix its self,and im fairly sure its caused by to much presure due to over heating
regards malcolm
regards malcolm
