auxilary belt questions
Hi people, my belt is making noises. (xantia 2.1)
At first I thought it was my exhaust gasket spiting, it's that kind of noise. It's more noticeable when the engine is under load at low speeds for example pulling off in first or second gear. Also worse when starting from cold, a short blip of the throttle settles it a bit but it's still there at idling and it's still wrong.
Does this point to a loose belt? I can twist it nearly 90degrees, so i'm guessing it's a bit slack. My car is the 2.1td so this belt does everything. And from what I know it's self adjusting too because i have aircon. Can anyone tell me which one is the auto tensioner pulley.
How much do these belts cost, and is it troublesome to put on?
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
I dont have a 2.1 in my Xantia but I have the later type 1.9, there are two tensioners, one automatic and one eccentric, I was having a noise at idle which turned out to be the bottom run of the belt flapping, when looking downwards at the spring loaded auto tensioner the smooth pulley was flapping in time to the noise, kind of wobbling back and forth, increasing ewngine speed stopped the wobbling, when I attempted to remove the belt it was nothing like the haynes book, I removed an allen bolt holding the eccentric tensioner and got the old belt off that way, it turns out that the wrong belt had been forced on, it was 14mm too short and was mighty tight, the new belt just slipped on and I set the eccentric tensioner fairly tight, I still have a noise coming from the bottom run but its a lot quieter.
Stewart
Stewart
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
I used to have a 2.1 Xantia and it only had the eccentric tensioner. It was a real pain to work on. Make a careful note of the belt run before removing it. It's very complicated. The size if I remember rightly was 6PK1738
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
whats an eccentric tensioner?
Is this whats gone on it? I think I will replace the belt as it drives a lot on the car and winter is coming, but no point getting a belt unless i get more info on how it's tensioned and if a tensioner of some sort needs replacing.
thanks for the code john, and yes the belt does take an aMAZEing path around the engine doesn't it!
- x 31
2018 Citroen C4-B7
- Contact:
It's a wheel - but it has an off-set centre spindle. Also it has a allen screw fixing to secure. Originally my car came with a 1725 belt on it, but it was almost impossible to get off and on, which is why I moved up to the slightly longer belt.deian wrote:whats an eccentric tensioner?
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
- My Cars: Xantia Exclusive 110Hdi Estate 1999
it wasnt a xud engine but my neighbour had a m reg escort td fully serviced 90000 miles cam belt changed at 65000 miles....
he called me over to listen to a strange noise coming from his engine....just as i was shouting turn it of the cambelt snapped.....turns out one of the pulleys had seized.....moral of the tale is seriously consider changing the pulleys when you change your cambelt .............
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
It may be the waterpump as well. This is driven by the timing belt. If the waterpump fails the cambelt can jump a few teeth and screw your engine. If its your aux belt this can also cause cambelt failure. To be on the safe side get all rubber belts changed. As it's a second hand car you cannot vouch for their reliability. I did mine all myself paying only for the belts (30 quid) but a garage quoted me 380 to do the work (independant citroen expert)
good luck
davetd
good luck
davetd
93 Xantia SX TD Manual Metallic Grey 145,000 Non Anti-Sink
very rich 'independent citroen expert' ?davetd wrote:It may be the waterpump as well. This is driven by the timing belt. If the waterpump fails the cambelt can jump a few teeth and screw your engine. If its your aux belt this can also cause cambelt failure. To be on the safe side get all rubber belts changed. As it's a second hand car you cannot vouch for their reliability. I did mine all myself paying only for the belts (30 quid) but a garage quoted me 380 to do the work (independant citroen expert)
good luck
davetd
