I need to to both of these jobs. I am guessing that changing LHM first and then the spheres is better than the other way around.
Alternatively is there any problem with draining, changing spheres and then refilling (assuming I can do all 8 spheres in one session)?
LHM or Spheres - which to change first?
C5 2l 2001 130K - daily use X-country (must change job)
Xantia 1.9TD Estate VSX 1995 111k - daily use X-county
3xBX 1xGS 1x16 TS - oh that was a Renault
You will evidently spill some LHM when replacing the spheres.
Why dont you do the job in one go ?
Replacing the LHM will not give better ride. It s just a precaution against larger future system problems.
Replacing the wheel spheres will solve any hard suspension issues - provided the normal ride height is achieved on engine start.
Anders (DK) - '90 BX16Image
There's a good chance changing the sphere's will get crud into the system so you'd be contaminating the good clean fluid if you've done that first!!
Mind, never understimate the improvement made with replacing the brown crud for the good stuff, although as Anders says, flat spheres will still remain flat!!
Andrew
Andrew
None of the spheres I have bought fron GSF have had any sort of paperwork - I just had the green globes with a felt pen GSF part code written on them.
