I am getting an awful noise from near my aux belt, like a rattle and jangle the auto tensioner has slightly kicked out could this be the cause.
It has caused the belt to jump over the edge of the hydro pump and strip a bit off the belt. How much are these auto tensioner things? How do i get there to change it?
gav425
Xantia Aux Belt Auto Tensioner
- PicassoPigeon
2002 Citroen Xsara Picasso 2.0HDi
125,000 miles
125,000 miles
To get at the auto tensioner you'll need to jack up the car in such a way that you can take the front right wheel off while the car is securely supported.
Then you remove the plastic covers in the wheel arch to gain access to it. If you're removing and refitting a belt it helps to remove the plastic box that holds the engine ECU as well, although it can be done without removing it...
Regards,
Simon
Regards,
Simon
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
Careful!!! When the auxillary belt starts to strip it is entirely possible for the 'stripped off' part to find it's way inside the cambelt cover and cause havoc i.e smashed cambelt pulley/broken cambelt and associated destruction.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
- KennyW
- My Cars: Current Citroen's
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Xantia 2.0 90hp estate
Xantia 1.9 TD estate - x 132
Hi Gav425,
There are several different varitions for tensioning th aux belt.
My xantia has the pulley tensioner and an additional damping spring which also tension the belt.
When my belt was shredding up it was the damping spring which has a bearing and pulley on it.The bearing had collapsed and was causing the belt to run out of alignment.
Will find the diagram on the offical citroen parts and post it.
I assume your aux belt it the really big one 1725 teeth!
Yours Kenny
Yours Kenny
C5 x7 2.0 HDi 160 hp Estate exclusive, the newbie
C3 1.4 petrol (SWMBO)
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Hi Gav,
I got myself a bit confused it is the tension roller which caused my problems and it's the length of the belt not no of teeth 1725
If you can access the citroen part site and look at alternator fixings you will see the tension roller (No 3)
Hope this helps.
It's a pain to replace in the car too
Cheers
Kenny
Hope this helps.
Cheers
Kenny
There are 2 very different variants for the Mk1 Xantia TD (aircon) :
0290 02 532051 ALTERNATOR AND FIXINGS DIESEL XU ET REFRIGERATION ET FIXATION ALTERNATEUR 3 POINTS JUSQU'A OPR 07358
http://www.citroen-pr.net/catalogues/il ... 320510.gif
09 - 5751 23 - ALTERNATOR TENSION ROLLER - DIESEL XU AND AIR CONDITIONING - Dkr1383,90
0290 02 532051A ALTERNATOR AND FIXINGS DIESEL XU ET REFRIGERATION ET FIXATION ALTERNATEUR 4 POINTS DEPUIS OPR 06809
http://www.citroen-pr.net/catalogues/il ... 32051A.gif
03 - 5751 30 - ALTERNATOR TENSION ROLLER - DIESEL XU AND AIR CONDITIONING - Dkr732,05
05 - 5751 81 - TENSIONNER ALTERNATOR - DIESEL XU AND AIR CONDITIONING - Dkr670,65
Anders (DK) - '90 BX16Image
- PicassoPigeon
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Hi Gav,
I see from the photo yours would appear to be an early Mk 2 with colour co-ordinated bumper 's etc.
Dalco do a repair kit for the xantia , thats what I bought.
I got it from a good motor factors for £70 which included a new belt tensioner and other bits and bobs.
Unfortunately there was slight difference between the bolts securing the roller so I couldn't use the old metal roller. The new one is plastic and be careful not to damage same or the belt is shredded again.
Or the alernative is the dealer at approx £70 for the part.
The choice is yours
All the best
Kenny
The choice is yours
All the best
Kenny
- Kowalski
- My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
Thats a late Mk1, my '97 is like that with the body coloured bumpers. They appear to be the same type of bumper as before except that they're painted body coloured instead of being "plain". They're most definately different to the Mk2 bumpers, the Mk2 bumpers have a smooth / glossy finish to them where as the Mk1 body coloured ones have a texture to them.KennyW wrote:Hi Gav,
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Hi Gav,
Thanks kowalski for the info, Gav I made a mistake the Company is called Dayco
Check there web site and you will get further info.
All the best
Kenny
All the best
Kenny
