XM driver's window anoyance
Post Reply
nino1
My Cars:
Post by nino1 »
Hi, it started as a work-dont't-work but after a few days turned into no operation for the drivers window switch (the one with the 4 buttons)
It did on accasion when i pressed up-full go up in increments rather than all the way. I noticed there is a bulb in this one (can't remember if it worked before) that is not illuminated.
Took out the switch giggled and contact spayed the two ends but no luck.
The haynes manual states both front side windows share the same fuse i discarded this problem as the passangers window is working fine.
Where would i be looking for the prob next?
What are the easiest checkpoints short of declaring the motor is gone.
Tnx.
andmcit
My Cars:
x 30
Post by andmcit »
The control relay lurking behind the driver's door trim area is the most likely suspect, followed by the actual one touch switch on the driver's door - then you're looking at possibly flexed wires in the door jam loom - [it does still happen on the Xm].
Doesn't sound as though you've got the duff plastic guide on the glass syndrome just yet if it's totally dead...
Andrew
rowanmoor
My Cars:
Post by rowanmoor »
I recently had a very similar problem. It would go up part way and stop. It turned out to the the switch - it had started disintegrating inside. The reason it would go part way was that you would press the 'auto-up' button, and then another button would give a 'blip' afterwards making the controler stop the window. I too had noticed the bulbs stop working in it.
Mine was fixed with a new switch (about £30 from Citroen!).
You could probably try a multimeter on the switch to get an idea if it is doing odd things or not (I expect one of the other buttons is jamming on if it is the switch). Do the other buttons work at all?
Cheers,
Rowan.
davetd
My Cars:
Post by davetd »
You'd be better going to a scrap yard and buying a handful of switches to try for next to nothing rather than buying new :roll:
93 Xantia SX TD Manual Metallic Grey 145,000 Non Anti-Sink
andmcit
My Cars:
x 30
Post by andmcit »
Great idea!
Mind, when did you last see an Xm ANYWHERE, let alone in a breakers!?
The last one's around are being pushed out for peanuts on ebay and mostly these appear to be being run into the ground as bangers - and the nice one's are being scrapped for their turbo engine to power a boy racer's Peugeot 106 that likely isn't insured etc...
...when they're gone, they're gone!! :cry:
Andrew
My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars.
x 1204
Post by Peter.N. »
I saw ten in France this week! and dozens of BXs.
Back to the plot. The switch is the most likely problem and they sometimes dont respond to an application of WD 40. You can dismantle them and clean the contacts but its a fiddly job and you are likely to loose something. There are a number of XMs being broken on ebay, I would have thought that would have been your easiest course.
Robin
My Cars:
Contact:
Post by Robin »
I agree that is most likely the switch but there are two versions. They look very similar but they do not function the same and use differing registers on the connectors to prevent your connecting the wrong switch.
Good luck with the hunting. Robin.
Citroens are dedicated to those who take a big bite - and just keep on chewing!
nino1
My Cars:
Post by nino1 »
Now, what would be the clever way to test it?
Surely i can shot some contacts (which?) to see if i get operation.
My Cars: Currently:
x 1204
Post by Peter.N. »
If you can get a circuit diagram you can but its a bit complicated - and I'm a TV engineer!
nino1
My Cars:
Post by nino1 »
Woah, i thought it was simple.
AndersDK
My Cars:
Post by AndersDK »
Might be worth visiting the XM specialists :
http://club-xm.com/forum2/index.php?act=idx
Norrie (noz) and his gang certainly knows the ins & outs of their XM's - and may provide a prompt answer - even a schematic :wink:
Anders (DK) - '90 BX16Image
nino1
My Cars:
Post by nino1 »
Peter.N. they claim it to be simple.
There are 6 contacts. 5 being earth and 2 closing it for the bulb.
5 and the rest should make it perform.
However no luck i get the 12v but shorting it did nothing.
nino1
My Cars:
Post by nino1 »
Ok, it seems its a contact behind the trim since when cramming the longish wires back into the switch cavity this morning i suddeny worked again before i drove some on the bumpy road.
How do i go about removing the door trim?
rowanmoor
My Cars:
Post by rowanmoor »
davetd wrote:You'd be better going to a scrap yard and buying a handful of switches to try for next to nothing rather than buying new :roll:
If you know of a scrap yard anywhere in our part of the country with an XM then let me know.
Last time I tried to find anything I heard a rumour of one on the coast somewhere - but it is not worth me driving 30 miles for something like a switch that has a good chance of being fairly dead too.
The online scrap searches sometimes find XM parts if you are lucky - but courier can be costly if it can only be found in Scotland.
Cheers,
Rowan.
wrinklet1
My Cars:
Post by wrinklet1 »
Hi, This problem seems to me to be a broken supply wire. Most likely where it comes from the A post into the door.
Paul
1xAmi,3xGS,2xBx,2xAX,2xSaxo,1xXantia mk I,2xXantia MkII,1xC1,2xC2,
Post Reply
