Hi!
I hear clicking near acc. sphere (3-5times depend on rapidity of start), when begin driving. And yet rear part of car sink somewhere 3-4cm when I remove leg from bake pedal (i have 1993 Hantia with automatic gear-box).SO, what does it mean about? May be is faulty or near the end of life compensator-brake control valve? All other time clicks i hear every 15-20secs...
Clicking...
The ticking on startup is not normal and I would check the accumulator sphere - which is easy. Run engine with car at normal height for a couple of minutes. Turn off engine and sit in the boot. The back of the car should sink a long way (15 cm or more) and then after 30 seconds or so rise to its original height - powered by the accumulator. If the height controller is working properly the car should rise when you get out and then sink to its original height.
It sounds as though you have gas in the rear suspension system - so doing 'Citroebics' (raising and lowering the car several times) may expel the gas and is the first thing to do.
Your 93 Xantia will probably not have anti-sink - and will have a single outlet pump. Please confirm if you need further information.
jeremy
