Converting xantia into trailer
I'm needing a trailer at the moment, and being as tight as I am, I'm thinking of using the rear floor pan, suspension etc from a knackered xantia that I've got sitting out the back. The only concern for me is the suspension.
At the moment the rear end is sat up in the air as the height adjuster is knackered. I guess once the rear end is cut away from the car the suspension will drop down to the lowest height.
I'm not actually bothered about having suspension for the trailer so it's no worries at that height.
Can anyone think of (or knows) any reason why this might not work, or knows how to rectify it?
Perhaps the rear rams will need locking(?!?) to stop any travel?
any thoughts would be appreciated!
Thanks!
Thanks!
2004 Berlingo Multispace HDI, 105000
I know it's not the best car, but it's the only one I've got to cut up. Not worried about having suspension anyway. It's not going to have anything heavy on it, just converted into a boat trailer for two plastic kayaks - so about 100kgs max!JohnD wrote:I would have thought a Xantia would be the worst possible car to use as a base for a trailer. As you say - it would have no springing at all.
You will end up with an impossible project. The Xantia has very little overhang at rear - making for a too heavy load on the towball of the towing car.
I'd thought of a similar project on a BX Estate. Trouble is that BX Estates are either total wrecks or still going strong around here
Same problem with the BX saloon : not enogh overhang to make a useful trailer.
BTW : re-using the suspension cylinder with a smartly fitted rubber block is as good as any mod including a coil spring. Keep the sphere as a lid against the rubber block.
Anders (DK) - '90 BX16Image
Hmm, a good idea.jgra1 wrote:Lee, butcher an old caravan?
should be able to get one free from someone...
then you have the tow joint, wheels, axle, rubber suspension, and even some electrics.
John
I've seen a couple on ebay, but their either too big, or millions of miles away! After all I am all the way down in Cornwall. Maybe a wanted ad in the local free ads rag might turn up something? Worth a go I guess
- New User
- My Cars: This is a dummy account added to fix some orphan posts.
Only problem with a caravan chassis is that it's big with little carrying capacity. They are designed to carry a light body so if you load up say a 2 berth base with earth / rubble or heavy stuff from DIY store it will probably struggle with such a weight. This is just my opinion would anyone like to back me up or disagree with me?
I'd probably agree with that, but as I mentioned in an earlier post, it's only to carry two (or maybe 3) kayaks, so as to save me getting salt water over the Xantia all the time, and to save driving round with the roof rack on all the time (can't be arsed to keep taking it off). So it would only have to carry a nominal weight anyway.Alec wrote:Only problem with a caravan chassis is that it's big with little carrying capacity. They are designed to carry a light body so if you load up say a 2 berth base with earth / rubble or heavy stuff from DIY store it will probably struggle with such a weight. This is just my opinion would anyone like to back me up or disagree with me?
Ahaaa ...
A small (short) trailer with a long towbar (towing triangle). That makes it a special purpose trailer - not just a special built trailer. Now I figure the Xantia saloon chassis still useable as a project then ...
An angle grinder, a bag of rivets, a power drill, a couple of lengths U-shape steel and a few bolts & bits - and you are done
You've got itAndersDK wrote:Ahaaa ...
Hopefully it'll be pretty straightforward. I just wasn't sure about the xantia hydraulics, as I don't know a huge amount about them.
