Hello All,
Can anyone tell me how to enter the code for the radio shown in link.?
Also, what is the 1st lockout time if wrong code has been entered. I left radio and ignition turned on for at least 45 mins, then I got hacked off with waiting and went in the house
I have the code. But no owners manual/booklet to tell me how to do it.
http://img.photobucket.com/albums/v676/ ... aRadio.jpg
Thanks a lot,
Greg
Xantia Radio from MK2
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
- Ross_K
- Lexia Available: Yes
- My Cars: 2009 Citroen C5 VTR+ HDi 1.6
2004 Toyota Prius
2004 Alfa Romeo 156 1.6 Twin Spark - x 110
To enter the code you just turn on the ignition and enter the code when it says 'CODE' on the screen. After you enter the last digit, the radio recognises the code and unlocks itself.
It did on mine anyway. It looks exactly the same as yours.
It's not like the ZX radio where you had some wierd procedure to get it to unlock.
If the code on the keycard isn't working, someone must have had it decoded in the past. If that's the case, you might want to whip the radio out of the dash and see if there is a sticker with a code number on it. If you pull out the ashtray you'll see the screws you need to get started with removing the fascia.
Re: Xantia Radio from MK2
Using the chanel No. buttons enter the appropriate code. i.e if the code is 1234 use button No's 1234 in sequence.Can anyone tell me how to enter the code for the radio shown in link.?
If you enter the code wrong try re-setting the radio by pressing the BND button.Also, what is the 1st lockout time if wrong code has been entered. I left radio and ignition turned on for at least 45 mins, then I got hacked off with waiting and went in the house.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
- CitroenNuts
I was going to write the explanation but its too long so I scanned a copy of the Instructions
Hope it helps
http://i53.photobucket.com/albums/g77/J ... iocode.jpg
Hope it helps
Homer Simpson: Weaseling out of things is important to learn. It's what separates us from the animals ... except the weasel
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 70
Hi. - in agreement with fo0ls above. And straight from the Radio hand book
On Clarion Radios, you do not need to wait to re-enter the code.
You can do it as many times as you like. If you have entered the wrong code, SIMPLY PRESS THE BND button to retry your code...
If its for example, 6352, as said above simply press the appropiate numbers on the front so it shows them in the display..
AFTER FOUR ATTEMPTS the unit will LOCK for one hour. You need to leave the radio and ignition (if needed) on for this time for it to reset.
Good luck.
Regards
citroenxm
Good luck.
Regards
citroenxm
Hi Guys,
A brilliant response from you. Thank you very much. This forum at it`s best.
Greg
Greg
