The accumulator sphere on my new V6 Xantia is desparate to be replaced, pump ticks every 1,5 seconds.
I know this sphere is desparate to be done, but i haven't had time to look at it on the car.
Does anyone know where the accumulator is on the V6, and will a basic accumulator for a Xantia do from GSF?
Thanks for your help in advance guys.
David.
V6 Xantia Accumulator Sphere
- DHallworth
- Donor 2023
- x 125
The accumulator sphere is the same on all Xantia's. IIRC its found on the front of the engine, the pipes running to/from it will be small ones whereas the Hydractive block (just behind the radiator) will have large bore pipes.
Berlingo Multispace 05 1.6 HDI
Picasso 02 HDI SX
Xantia 97 TD VSX
Xantia 96 Activa
Picasso 02 HDI SX
Xantia 97 TD VSX
Xantia 96 Activa
- My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX - Contact:
Yes, it's attached to the front of the engine. I used a GSF one on mine and used the hammer and chisel method to remove the old one, though I'm not suggesting that you should do the same.
Lexia ponce
Lexia ponce
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
- DHallworth
- Donor 2023
- x 125
