CAr audio on C5
Post Reply
AtitudeJim
My Cars:
Contact:
CAr audio on C5
Post by AtitudeJim »
Hi... does anybody know were on the c5 can i pass a power cable from the batt to the trunk to power an amplifier?, is it behind the fusebox on the engine bay were the cable can pass? since its the only place were i think it possible without drilling a hole, wich i dont want to do.
cheers :wink:
(04) Citroen C5 2.0 Hdi 110hp (uk)
(90) Pug 205 1.8D (uk)
(92) Vw Polo G40 (pt)
JohnD
(Donor 2022)
My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1
x 72
Contact:
Post by JohnD »
When I wanted two thickish wires from battery to the boot of my C5 estate for powering caravan fridge and lighting, I ran a wire from the battery to a fuse holder fitted close to the battery. Then I threaded the two wires into a length of PVC tubing, ran them down the back of the engine, threaded them through the conduit covering the fuel pipes and took them up over the fuel tank. I drilled a hole in the plastic cap (the one to access the fuel sender unit under the rear seat) and then under the carpet into the cargo area where the two relays were fitted.
AtitudeJim
My Cars:
Contact:
so you took the cable to the trunk through the exterior (under the car)....
i think that must be a mesh of cables that goes from the engine bay into the glove compartment were there is a second fuse box , but im not sure... if yes... it would be much safer.
ill keep your tip in mind if i dont find an alternative way.
My Cars:
x 728
Re: CAr audio on C5
Post by wheeler »
AtitudeJim wrote:is it behind the fusebox on the engine bay were the cable can pass? :wink:
do NOT use the big grommet at the n/s behind the glovebox,it will eventually lead to water getting into the BSI,you really dont want that.
BonceChops
My Cars:
Post by BonceChops »
JohnD wrote:threaded them through the conduit covering the fuel pipes and took them up over the fuel tank.
That is how I am thinking of doing it on my Xantia. There appears to be a spare entry into the fuel pipe conduit. I wonder if some cars have 3 pipes from engine to tank.
Now Citrtoenless
406 V6
My Cars:
Post by 406 V6 »
I've sent you a pm matey ;)
Francisco
C5 2.0HDI smoothly riding on 1.8l version spheres :D
When the hearts beats like a pressure regulator you know it means one thing: Love
Citroën - pacemaking since 1955
AtitudeJim
My Cars:
Contact:
its done :)
thanks for all your help, ill put some pictures later of the wiring from the battery to the boot, for sure it will be very helpfull for other menbers that might need to do the same :wink:
Post Reply
