xsara mist jets
xsara mist jets
There has been some posts on this site regarding upgrading on 306/zx washer jets to the xsra mist jet type. Is it a straight swap onto a '94 zx??
cheers
alastair
cheers
alastair
Zxtd Aura converted from 1.8i Petrol - Lowered, 20psi boost extra fuel - weeeeeee!
MK2 Cortina 1600e
Honda Acty Romahome - 545cc!! - (the "beast")
MK2 Cortina 1600e
If your car is a ZX then you need Peugeot mist jets
If your car is a 306 then you need Xsara mist jets
Xsara mist jets are the ones that go in the middle of the bonnet
Peugeot mist jets (407 if i remember) are for cars where the jets are underneath the bonnet right at the windscreen.
I think thats right!
Volkswagen Golf 59' 1.6TD S
The Xsara jets fit both the Xsara and the Peugeot 306 with no modifications required..
The Peugeot 407 mists jets do NOT fit the ZX. The input on the existing ZX jets is horizontal from the opp end to the jet exit. The input on the 407 jet is at 45degrees in a upward direction horizontaly, at right angles to the direction in which the water exits the jet. And on the 'wrong side. i.e. the side away from the pump..
Due to the inlet being at an upward angle (remember they are actually upside down when in situ) you can't get the jet to sit flat up against the underside of the bonnet, I am going to try to fit mine somehow to the lug that is near the jets, situated about half an inch away from the underside of the bonnet about two inches to the right of the existing jet. I will also need to extend the length of water pipe. so will buy about an extra 2 yards to give myself plenty of leeway and replace all the pipes... But I need warmer weather first!!
In case I damage the old jet during removal, and can't replace it if things go wrong, I will do the passenger side first (furthest away from the pump) that way if problems arise fitting the new jet I can seal the pipe and use just the one washer untill I sort it out. (This would not be possible on a car with two wipers.)
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
Ross.. erm I haven't taken any pics, mainly because I dont know how to post them on here anyway.
Hhmmm I could borrow a lil m/phone. Take some pics and maybe get them into my PC. If I manage that, I could email them to anyone interested..
Where the jet goes directionaly depends on how you fit it to your ZX. I intend to fit to the lug as stated, that way I hope to be able to bend and twist the lug with a pair of pliers untill I get the jet to hit the screen in the right place.
Mez, I dont understand your question? Whats wrong? Sounds like a lack of water pressure? Or is it a directional problem? And on what model car??
EDIT - UPDATE> have taken some pics.. now I need to get them into my PC.. will update again later..
http://i16.photobucket.com/albums/b12/J ... C00016.jpg
http://i16.photobucket.com/albums/b12/J ... C00015.jpg
Big question is - - - did it work?
Interesting idea Ross. and the panel is removeable, but not a good idea to mess with it in this weather as the plastic will be very hard and brittle.
I removed mine last summer to make the wiper park the other side, but it was a very hot day and the plastic panel and its rubber cover were quite pliable (bendy).. Even so, it wasn't all that easy to do.. lol. ...
I tried putting mains pressure through one of the 407 jets "just to see what the spray looked like".. lmho.. I got soaked! so did the draining board, toaster, kitchen curtains, mirror, window, and the dog... It's great being daft. lmho ..
James, how are you getting on with these.
I've been waiting for my bro to come over so I can nick one of this new jets & experiment with mounting them on the plastic scuttle. As I'm not sure if the angle will be right for the jets.
If it works, do you know if they do misted heated jets? or is it best I ask if/when I order them?
