SWITCH ??????????????
- WELSHVIKING
- x 4
Hi, I have a 1996 / N reg xantia 1.9. td sx estate with the fog lights switch on the stem along with the main lights. However today i noticed a switch along side the hazard switch and heated rear window switch it was a rear fog light switch ??? as i have already said my foglights are on the lights stem so i think this switch has been put in as a replacement...so what is it...i think maybe the air con switch as i have auto climate control on this car but cannot see a air con switch anywhere ..can anyone just confirm what it is please ?.Thanks Colin
CURRENT CARS:-
2019 CITROEN C3 AIRCROSS 1.2 FLAIR PURETECH 110BHP MANUAL (WIFES CAR)
2020 CITROEN AIRCROSS 1.2 FLAIR PURETECH 130BHP AUTO (MY CAR)
How long have you had the car, you seem to be finding so many new things with it
From memory mine is : Clock - Hazards - Rear Demister - Air Con
AirCon button is like a snowflake and the colour is green - yours should have aircon if its an SX and you have the Auto on the heater controls
Me' thinks you have a fog light switch in place of your AirCon button 8)
Just ran to the car to check and they are in the right sequence
Volkswagen Golf 59' 1.6TD S
- WELSHVIKING
- x 4
Just as i thought...only had the car for 5 days as my hdi sx needs the dashboard out and i needed another car while i plod on with that job...
Thanks for your reply...Regards Colin
CURRENT CARS:-
In agreement to Vikings original statement, both his front and rear fog lights are operated independently using the 'Indicator Stalk' just like mine unless ive read incorrectly.
I cant see him having two working switches (button switch on dash AND the Indicator stalk action) unless the owner before Viking was thinking on the same principal as yourself Clogzz and 'put in' a fog light button switch not maybe realizing both sets of fogs were operated on the Indicator Stalk or maybe even the Indicator Stalk was faulty at some point and therefore did a bit of wiring and used a button switch like my ZX for example.
If anyone is still following me then please let me know as ive lost my way and could do with some encouragement
Any other suggestions?
