Buying with no keypad code
I was looking at a cars at the weekend at a salvage auction(see my other post) There were a few peugeots and citroens which had no code with them, and no V5. I know a dealer will issue a code if you have a V5 however you cannot get one for a write off until you MOT it. Is there a way round it?
- My Cars: Current - Slightly modified 2016 Pug 308 Puretech 130 Allure
Past:
2003 - 206 GLX TU3JP & 206 SE ET3JP4
1995 - 405 Executive XU10J2
1996 - 406 GLX XU10J4R
1994 - 405 GTX XU10J2 - x 1
The default factory code is 1 1 1 1, Try that first.
The owner can change the code whenever they want so it could be any 4 digit number.
If its the later S button Cat 2 keypad you only get 3 goes at the code before the keypad locks you out for 30 minutes!
The only easy way around it is remove the keypad & send it away to have the code extracted, About £25
On a diesel the fuel pump stop solinoid is what stops the engine running, It has a very strong steel security shield around it & isnt easy to bypass in a hurry.
On a petrol its the fuel injectors & coil pack that are locked by the ECU, NOTE: Powering up the coil & fuel injection relay will NOT bypass the immobiliser, It will stay LOCKED!
Unless you know a Peugeot / Citroen technician who can help you
