Xantia heated washer jets
Spotted on Ebay a set of MK 2 heated washer jets(cant sleep you see ).
How would i be able to wire these up to mine?If i could?.
Night night.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... %3AIT&rd=1
Night night.
53`406 est SE Hdi 140,110k
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever - x 16
- steviewonder7
- Kowalski
- My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
The heated mirrors are on the same circuit as the heated rear window, theres a relay too so I think there will be some wiring that is easilly accessable.
The thing that I did notice is that the leads on those jets are rather long, meaning that even if you do have the correct plug/socket on your wiring loom, it could be some distance from the washer jets. Needle, haystack?
Yes they are long.I may have a bid on them & see.I reckon if you could get the cable through the bulkhead into the foot well,maybe tap the wires into the mirror circuit by the doors.If not,wire in a fused feed & earth via a switch & simply turn them on & off.
I had them once on my Rover VI.They heated up every time you turned the engine on,for 10 mins.Never had to carry any de-icer .
Didn't realise that mine had them... the Exclusive anyway! I know it is fitted with the 'winter pack' but thought it was just headlight squirters and heated seats.... must try them and see. Perhaps I can find some wiring! (have you ever looked in the engine bay of the V6)
Sutton Coldfield, West Mids
Xantia V6 Exclusive (2000
Xantia 1.9TD SX (2000)
Previously owned
Xantia V6 Exclusive (97)
XM V6 Exclusive (95)
AX 1.4
Previously owned
AX 1.4
A slightly different approach, if you're after heated washer jets, is to utilise the coolant temperature. My old SAAB (RIP) had a simple heat exchanger fitted in the upper rad hose. This was a unit of coiled copper washer pipe wound around a metal rad hose - and it worked quite well.
I don't know how well this would heat the washer water with some of the high output washers but the Xantia washers don't put out gallons/second like some newer cars do. So something like this may work. There must be a number of cars on the market that used this type of washer water heating in the past.
Pug Rifter long (20) - 41mpg - Gutsy for a 1.5!
Xantia 1.9 TD Temp.2 Break (97) - 208K@42mpg - Resting again.
Berlingo Multispace 1.6 16v (51) - 184K@36mpg - My shed! Still runs 15° retarded...
