antigel
antigel
Hi can anyone tell me if citroen antigel is compatible with ordinary anti-freeze and vica versa as i do not no what is in my xantia and need to top it up for the winter?
2004 C3 XTR HDI 16V 92bhp
2004 Xsara Picasso Exclusive HDI 16V 110bhp
1989 Peugeot J5 Hymer B694 2.5td intercooled 8v 96bhp
If you own a Citroen : always purchase genuine Citroen parts & fluids.
If you own a VW : always purchase genuine VW ...
If you own a Toyota : always ...
If you ow ...
8)
Citroen antigel is as good as any antifreeze on sale from your lcoal ...
Any type of anti-freeze used these days for street cars can be mixed.
If you dont have any other records on the coolant fluid in your Xantia - than it may well be more than 3 y's old - then you may as well replace it.
In UK it will be more than adequate to mix it 1/3 antifreeze 2/3 tap water.
Unless you frequent the Highlands in which you may need half and half just to catch that record winter ...
If you ow ...
8)
Anders (DK) - '90 BX16Image
- Contact:
Dont mix OAT /HOAT with Glycol or priordeal soup will be the result.citronut wrote:i thought you cant mix these modern antifreezers,it is said in the garage trade that you must not mix some of them im not quite sure which coulers you cant mix
regards malcolm
I would also mix with deionised / demineralised / distilled water ratehr than corporation pop.
BX
Xantia
Shed
Set of Spanners
Kettle
Xantia
Shed
Set of Spanners
Kettle
I put O.A.T. in my BX a couple of months ago- it said on the container to drain out as much of the old antifreeze (i.e. glycol) as possible, which I did- and there's been no problems so far (in fact, the heater knob no longer sticks!!!), so as long as there's not too much of the old fashioned stuff in there shouldn't be a problem!!!
What colour is your existing antifreeze?? The O.A.T. is a girly shade of pink......
- fastandfurryous
- Location: On the road, travelling at high speed. Meep Meep.
- x 4
Just to confuse matters totally, there is also some Glycol antifreeze (labeled as "extreme") which is also a girly shade of pink..... so you can never be sure.bxbodger wrote:What colour is your existing antifreeze?? The O.A.T. is a girly shade of pink......
Drain, flush and refill is the only way to be sure.
This is not a signature.
