Yesterday morning the car was frozen ,so i started it to warm it up.
It was fine for about 1 minute then cut out , management light came on.
Tried several times to start it again it ran then spluttered a bit and died management light still on.
Checked for fuel to filter ok , fuel is pumping also. (no brass particles in filter housing)
It turns over fine.
Even the AA couldn't start it
Any ideas people
Help
Help
2013 Berlingo Multispace 1.6 XTR 115bhp
2003 2:0 HDI Dispatch Van 186000 miles......gone
2000 Xantia Hdi 90bhp Forte Estate 97000 miles gone..........to heaven
New High pressure Fuel Pump and Patched ECU , Blower Module fixed by CitroJim
Ckeck the following;
Faulty fuel shut off valve,
Blocked or collapsed air filter,
Something blocking the exhaust ( we had a customer who must have p...d somebody off as he had a potato stuck up the pipe so it would not run!)
Wrong fuel.
Have you compressed the fuel bulb until hard?
Cam belt slipped a couple of notches, teeth missing?
Best of luck!
Wrong fuel.
Best of luck!
Cheers!
John
John
It wont start if cambelt has missed anyhow.
The description sounds to me like it does not get fuel. If it was getting fuel and would not ignite because of a timing issue - then it would smoke smelly clouds from the exhaust. Points to an electric fault in either fuel stop valve or pump.
Anders (DK) - '90 BX16Image
