I parked my car in the morning outside job and after 10 hours i couldnt engage any gear at all with the engine running. I switched the motor off engage second gear and than started the motor. Got home in second gear.
The clutch had been changed a year before. What can it be?
THANKS
XM clutch 2.1 TD
I believe that all RHD XM TD's have hydraulic clutch release (unlike all petrol and LHD 2.1 TD's, that have cable release).
So there's a fair chance that you have a fault in the clutch release mechanism. I'm aftraid I cant help you more than suggest the Haynes BOL (which seems to cover the area reasonably well) since my 2.1 is LHD and has a cable.
//NiSk
//NiSk
OK. Open the bonnet and get someone else to depress the clutch pedal. You can see the end of the clutch cable down between the battery and the clutch housing. You should be able to see the clutch release arm move. If not, either the cable is broken or the attachment at the pedal or clutch housing end have given way. If it does move but he clutch still doesn't release, the relase arm fork (inside the clutch housing) may have cracked so that it no longer applies any force to the release bearing.
//NiSk
//NiSk
Hmmm - if the release arm is moving you can try adjusting it (move the nut on the cable sleeve so that it takes up any slack in the wire) if this doesn't help then I'm afraid your going to have to separate the clutch housing from the engine. On the 2.1 TD this can be done without completely removing the gearbox - there is just enought space to move it toward the LH front wheel and allow you to get you hands inside the housing and get at the clutch assembly. However, its no short job - the drive shafts have to be removed and you have to be able to get under the car - preferrably using a grease pit or car lift.
//NiSk
//NiSk
No (laughing to myself) im not a policeman . So you have pressure on the pedal, but you cant engage the clutch or change gear. Hmmmmm, when you had the clutch changed who did the work? Are they a decent garage, or just somewhere that you "picked" out of the phone book? It could be that the pressure plate is knackred - a few splines have broken off it, giving the pedal pressure but at the same time not exerting enough pressure onto the friction plate. Or they used a cheap clutch kit. I once came across a Vauxhall Carlton that had a "new" clutch fitted roughly a year old, and it was knackred (a cheaply made eastern european part). Did your Xm sink down on something, and then by pure bad luck bending the selector rods? - Alex.
