CX blower control S1
Anyone know anything about S1 CX blowers? Mine only works on full speed, dont get anything in the other positions at all.
From memory I believe the series I had a rather simple blower speed control circuit. Much like the BX series I.
At full speed the controller wheel directly earths the blower.
At medium & low speed - 1 resp. 2 resistors - are connected in series to earth.
It's then the medium speed resistor that is burned/corroded out.
You will have to disassemble the air intake tower down to the blower to get at the resistor pack. Not as frightening as it seems - but the lower part can be a real teaser to get out.
Or you may modify the whole lot for the series II transistor module control circuit [:D]
- as this is simply inserted in the full speed connection at the control wheel [;)]
