Info about Saxo 1.5 D '96
Seen an ad for one of these - it's a very unusual vehicle for scandinavia and I wonder if anyone on the forum could fill me in with some info - especially about the engine.
//NiSk
//NiSk
'13 3008 1.6 HDi GripControl - x 996
The 1.5 engine is much better than the 1.4 fitted to earlier AX's, being all cast iron block. The Saxo is OK, as far as it goes, but the pedals are a long way offset and there have been quite a few reports of severe corrosion around the rear subframe mounts / chassis members. Beloved of modifiers over here! But really, it's a typical small car - I'd avoid like the plague, but then big cars (well, those wearing Citroen badges anyway!) are cheap over here!
Saxo AKA Peugeot 106. Good small car if you can live with the driving position limitations outlined above. (If you are tall or intend to make long journeys, forget it). The 1.5 litre TUD5 is an outstanding unit for economy and performance, with most of the design flaws of the previous generation of diesels designed out. For example, the cooling system is virtually self-venting and the glow plugs are fully accessible. Do not overfill this unit with oil - no more than 3/4 full, or else the timing belt oils up.
Following the notes about structural rust on these vehicles I have kept a very sharp eye on my 7 yr old 106. I cannot find any evidence of rusting around the front legs or rear subframe mounts, and the outer panels are obviously galvanised. The problem area is under the boot floor, which looks like a scrapyard - waxoyl needed in all seams and inside the hollow sections here.
Otherwise, a brilliant car at today's fuel prices (65 mpg in town, repeatably).
rotodiesel.
rotodiesel.
I already have a big Cit - one of the biggest - an XM 2.5TD Break and the road tax is killing me! So I though I'd try and pick up a lightweight diesel. The XM costs around £500/year in road tax over here in Sweden. If the spec I have seen for the Saxo is correct, that it has a kerb weight of around 900 kg, that would equate to a yearly road tax of about £150. An if, also as specified, it has a fuel consumption of around 55 mpg (5.0 l/100km) then it would be a good replacement for our second car (currently a 1986 Audi 100 Avant). I'm going to keep the XM of course - there's nothing like it for long journies, but the Audi has seen better days and is falling apart at the moment.
//NiSk
//NiSk
For its cost, the 106D is probably the best small car I've ever owned. Obviously, due to PSA parentage, there have been problems, and the reliability will never match Japanese standards until they stop buying bits from Valeo. However, parts are cheap and pattern parts readily available here, so no complaints.
The diesel is a real cracker, and the handling will put a smile on your face - I hope you're not too tall to fit into it!
rotodiesel.
rotodiesel.
More questions: is the 1.5 D found elswhere? (except in the Pug 106, of course). Where did it come from? Is it a down-sized 1.9? Are there any turbo versions? Is it fitted with an EPIC or a Bosch injection system? Are the body panels similar to the 106? (insurance problems otherwise - they appear never to have been officially imported to Sweden).
ANDERS DK if you read this, is/was the Saxo sold in Denmark?
//NiSk
//NiSk
- My Cars: Current - Slightly modified 2016 Pug 308 Puretech 130 Allure
Past:
2003 - 206 GLX TU3JP & 206 SE ET3JP4
1995 - 405 Executive XU10J2
1996 - 406 GLX XU10J4R
1994 - 405 GTX XU10J2 - x 1
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by martyhopkirk</i>
The 1.5D started life in the AX before the Saxo/106 its also been used in the Rover Metro/100. I couldnt kill mine when I had one, the rest of the car fell to bits first.
Ill think you will find the AX & the early 106s had the 1.4 litre TU diesel engine.
1.5 litre TU diesel came in with the Saxo & second generation 106
I've had an AX with the 1.5D engine so yes, they exist!
In practise I found it only slightly more economical than a ZX 1.9TD, on my commute. However the ZX is luxury compared to the AX and has some measure of performance...I imagine the extra weight of the Saxo (over the AX) would make the Saxo slow to say the least.
I was not impressed by the cramped engine bay, fuel filter change was a pain (compared to the ZX).
As you might have guessed I sold the AX and got another ZX TD...
Simon
Simon
