I am getting really confused about the type of ATF to be used in my xantia estate (97). I read from numerous forum that xantia have ZFHP14 auto box that should be filled with Dexron II atf and not Dexron III. The owner's manual specify TOTAL 4AT, however when I looked up at TOTAL's web page, it says the TOTAL 4AT is Dexron III compatible atf. My car is currently running on TOTAL 4AT, am I poisoning my auto box?
http://www.alllinuxcd.com
xantia atf
I can confirm the owner's manual specify TOTAL 4AT.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by tj</i>
TOTAL 4AT is Dexron III compatible atf. My car is currently running on TOTAL 4AT, am I poisoning my auto box? <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Might be best to use what it said at time of manufacture, probably Dexron II.
See following 4-page story: http://www.aussiefrogs.com/forum/showthread.php?t=25121
