Hi!
Did anyone changed Auxiliary belt on Xantia 1.9TD with AirCon?
Looks like an easy job, but it is not
There is an automatic tensioner pulley, and it is not clear how to lock it... Haynes mention some special tool which should be inserted in the pulley holes to lock it.
Did anyone seen this tool - what it looks like? Is it possible to to use something else instead?
This is the AirCon Xantia 1.9 TD with automatic tensioner on the aux belt..
Thank You.
__mmx__
How to change aux belt on Xantia
If it is like my Citroen, then you need a 3/8 ratchet. You insert it in the square hole in the en of the tensioner and pull (or push depending on which side you are). The belt should loosen and you can remove it from the lower pulley so you can release the tensioner and remove the belt.
And as Haynes BOL would say, installation is reverse from removal.
