Front Caliper Piston Retractiom
I know front pistons need to be turned as I managed it on my BX many times.
However, my C5 has defeated me so far, in fact the piston has come out more and I can't even get it back to as it was.
It's far bigger than the BX and won't budge although is not seized. Managed to turn it (both ways) with an air filter tool but levering it in draws a blank.
Car is now undriveable until I sort it. Help!!
You probably will have to wait for the opinion of the experts on the subject, but I would say that the fluid prevents it from going back in.
Maybe opening the bleed screw to release some fluid will enable it to go back in.
Check for burrs on the metal from using the filter tool.
The burrs would need smoothing, otherwise the piston may bind in time.
According to the schematics on Citroen PR-net the C5 handbrake is working on the front calipers. The way the handbrake cables are connected is not seen as they are hidden on the rear of the calipers shown.
Also there are no exploded view of the caliper internal parts.
The problem then seems to be like <font color="red">macaroni</font id="red"> describes it.
Just did this job on my C5 last week! I bought a piston retraction tool from ebay, it slots into the piston, and then you just put a socket on to turn it. If you turn the piston the WRONG way, it comes out to its limit, and you think 'Oh s*%£, I've broken it!' All you have to do is turn it the other way, and it will go back in, but it does take while before anything happens, and you do need to push as well as turn. The pistons on each side turn in opposite directions.
You don't need to release the bleed nipple.
Hope this helps.
Regards
Philip
Hope this helps.
Regards
Philip
http://www.franklin-tools.co.uk/ got the special tool TA896 for C5.
However Philips' tool seems easy to copy as DIY [;)]
