Xantia multichanger
Xantia multichanger
Hi, I will be fitting a Clarion DC628 to my 99 Xantia, how difficult is it to run the bus cable up from the carpet past the ashtray and heater controls up to the rear of the stereo. Thanks in advance Toneski
not too bad, pull the carpet down nearest to the centre console in the passenger foot well, pull the stereo out, if you have small hands, then you will be able to pass it upwards that way, if however like myself you have large hands, then you may need to remove the plastic surround which the stereo sits in, then you can pass the cable up.
