Xantia 1.9 T-Diesel stop solenoid
The stop solenoid on my 1996 Xantia 1.9 T-Diesel appears to be open circuit, so I can't get fuel to the injectors. It's Bosch, with the four wire connection. It's held in by 2 shear bolts in recesses which make it almost impossible to remove. At the moment it all measures o/c between any combination of the 4 pins, although I have 12v on 2 pins of the other half of the connector that plugs into it. Anybody know what the circuit looks like and what resistances I should be seeing? And how do I remove it from the pump?
'13 3008 1.6 HDi GripControl - x 1003
Hmm, it's not very straightforward. There should be a live feed, but the other wires are to do with the keypad communicating with the electronics in the solenoid - no idea what does what. Does the keypad still give you a green light after you enter the code?
Unfortunately there's only way to remove the solenoid, and that's to remove the injection pump, and then drill the security bolts out.
From previous posts I understand that it's possible to break into the loom somewhere, and supply a live to the solenoid which bypasses the immobiliser function, however, details have not been posted!
