brake bleeding
brake bleeding
The new Xantia needs its brakes bleeding in my opinion. The LHM has recently been changed, as has the accumulator but it's pulseing like a good un under braking. I've looked at the method in the Haynes and it seems ok but they do not mention whether the hydraulics need to be depressurised or not first. I presume that they DO NOT. Is this correct?
Just one other thing to remember- the rear suspension must be at the high position to keep the brake lines pressurised when bleeding the rears.
Also ,to avoid snapping of the bleed nipples,a ring spanner is a must as is pre-lubrication ,especially around the rear nipples and careful slackening of same.
If really stuck,some heat and shock around them will help.
If you want or must do the job single-handedly,then a piece of wood jammed between seat and brake pedal does the job nicely.
I've wondered about this, do you bleed the brakes by constantly topping up LHM container? What happens to 'used' fluid? Are the bleed nipples likely to be mashed? I don't think my fluid has ever been changed, if it has then i very much doubt if the brake ends have been bled of air. Could this accountfor the 'on,off' stopping i'm experiencing. I just put it down to 'the abs'.
I went to the aquarium shop and bought a long piece of plastic pipe, it reaches from the rear bleed nipples all the way to the reservoir, i sat in the seat, brake pedal pressed and raised the rear of the car, it was quite a long time before the offending bubbles came past me, clearly visible through the clear pipe.
Stewart
Stewart
- fastandfurryous
- Location: On the road, travelling at high speed. Meep Meep.
- x 4
hmm well I had a go. I got two different thicknesses of tubing of course one was far too wide and the other too narrow. I had to use the wide one in the end and most of the LHM ended up on the road.. Anyone know the opimal size in mm for the tubing? Also how long did you spend bleeding each side and how much fluid did you draw? I found it difficult to get much fluid out without actually almost removing the bleed nipple nut thing! Then of course when I slackened it right off LHM escaped from various different places. I've put it all back together since then and the car does brake a bit more smoothly but it's still not right. Perhaps I should have persevered or gone to another shop to find some better fitting tubing..
- fastandfurryous
- x 4
