radio lights
- My Cars: citroen c5 hdi 2.2 auto estate
radio lights
does any one know how to get the lights on the standard radio workin mine went out the other night one side of the lights went out then the other side went out about half an hour later and it's annoying trying to shine a torch on the radio and drive and press buttons all the other lights on dash and heater controls are working so i dunnpo whats wrong with it
not sure I understand ths comment.... I replaced the bulbs in my Clarion using the Maplin ones and it all works fine.
First thing to do is to open the unit and see what type of bulb is in there, then buy the appropriate ones - while the unit is open, may be worth checking the voltage across a blown bulb to confirm that 12v type is correct.
Just re-read, noted capless bulb - but this should not be a real problem so long as they fit the panel - just use a sharp knife to clean the wire and tin it before trying to solder to the cct board.
