XM non-starter motor
I've started having to tap the starter motor on my xm 2.0i in order for it to go, possibly due to a sticking solenoid. How hard is it to remove the whole motor to give it a good clean and is it worth doing anyway? Also when the engine is up to running temperature and ticking over the oil, coolant, brake and stop lights flicker even though all fluid levels are fine.The lights go off with a touch on the throttle. Any advice gratefully received.
As regards the starter motor, if it's anything like a BX, the carbon brushes sit on the rear of the commutator and sit onto a flat surface as opposed to sitting on the side and a circular surface in a lot of cases, as a result as they wear, they get sticky and the springs that hold them against their working surface also lose tension with heat & age. The chances of it being a solenoid are there, but more likely I'd suggest it will be the carbon brushes.
Not all that hard a job to rebuild if you have the time and patience to have a fiddle.
I did it on a BX and detailed it here
http://www.aussiefrogs.com/forum/showthread.php?t=23512
which should give you some idea of the amount of time & money involved.
Alan S
Alan S
