<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Mandrake</i>
My Dad's 1994 SX 2.0 definately doesn't have ABS, no computer, no sensors, no place to mount the sensors. According to what I've read, only the VSX, Exclusive and Activa had ABS in Mk1, while in Mk2 the SX also has ABS and air bags as standard. (But not Hydractive 2 or Electric seats...)
Then might I suggest it is not an SX?
My 1994 2.0 SX had ABS - I had to replace the ECU. Late in 1994 they chanced the ECU. The early ones were about £800 (this was in 1998) the later ones were about £400. Just my luck that I had the earlier one.
When I bought my first Xantia I did my research, I wanted ABS and the lowest model with ABS as standard was the SX. The exception was the N/A 1.9D which didn't.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by citrojim</i>
What does the ABS warning lamp look like and where on the panel is it?
It's a yellow slippery road symbol. If you shine a torch at the lamps you should be able to make it out. All the cars will have the lamp though even if they don't have ABS.
Why has my Xantia got ABS Sensors on it?
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever - x 16
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Homer</i>
No, it's definately an SX. No doubt about it, it even says so on the original registration papers. (And it was sold new in this country so that was its first registration)
Maybe it varies by country then, because all the (Mk1) SX's I've seen over here don't have ABS. It may be available as an *option* on the SX however...
Also have a look at this page:
http://www.myweb.com.au/citroen/sub_xantia.htm
It refers to the australian Mk2 Xantia's and says that ABS is now standard on the SX. (Implying that it wasn't in earlier models)
As far as I know the LX model was never sold in New Zealand or Australia, and I've certainly never seen one for sale...
Regards,
Simon
Regards,
Simon
Jim,
If you test the abs and find that it doesn't work, do a little digging around on the forum - somewhere there's some threads which show the sensor connection pins in the big plug that goes to the ECU. My using a multimeter, you can quickly and easily see if one or more of the abs sensors is faulty. Could be that a previous owner disconnected the ABS system to try and sneak it under the radar at MOT time, but you'll cop for it now.
I had a problem with my rear left cable - it had been worn through from rubbing on the wheel ( the night before MOT ). I got some bull-nose connectors and sockets from an electrical store, cut the wire near the wheel, put thee on, and it worked and passed the MOT.
i would check the bulb first because if its just a fault in the system the lamp stayes on all the time,even if fuse has blown,i know of a bx that had lamp on continuasly fuse 14 had blown replaced this and it was fine for months untill the owner stamp on brakes it blue fuse again,some thing in ABSunit was causing dead short when opperated regards malcolm
- Kowalski
- My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
My '94 is a special edition, Dimension SX and has no ABS.
It doesn't have electric rear windows which I believe the SX should have, it seems to be one of those special editions where you get less equipment than standard...
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Sorry, didn't notice you were from the other side of the world.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Kowalski</i>
Dimension was based on the LX with a few SX bits thrown on. Foglamps, height adjustable drivers seat (I think) and maybe some other bits. I remember them because I was using the presence of foglamps to pick which cars to look at when wandering the auctions.
Interesting,
My Dad's "SX" which doesn't have ABS does have electric rear windows....so it can't be a Dimension SX in disguise...
I guess the answer here is that there are a lot more variations per "model" than we thought... and quite likely some of them country specific, so the moral of the story being check out whether the specific features you want are present, rather than relying on the model designation...
Regards,
Simon
Interesting,
Regards,
Simon
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Looking at that spec sheet the Australian market SX had some things missing compared to the UK SX and other things (such as automatic wipers) which were only ever found (in the UK) on the Exclusive.
I doubt we have many Australian market Xantias over here but there is the possibility of grey imports which may be Mainland Europe spec but RHD.
I should add that toward the end of the Xantia run they started fitting all sorts of optional extras as "standard".
Still simpler than the BX lineup.
According to the Parkers website the SX only had ABS as an option, only being introduced as standard in 1999. How accurate that data is I am not sure.....
On the other hand you could always bung your VIN number in here to see what equipment you have:
http://www.citroen-pr.net
Its common practice for manufacturers to fit so called options as standard - I'm sure no-one actually ordered my BX estate with it - it was just on the car that was available for purchase at the time it was wanted.
Many BMC cars of the early 60's listed the heater as an option - but I never saw one without it.
Now paying for its another matter and could form the basis of some bargaining - since the abolition of car tax it isn't as easy to work out what the dealer's margin is. (was 10% of factory gate price - so simple arithmmetic gave you the factory gate price! - quite interesting actually)
Jeremy
Jeremy
