Boost Gauge
Boost Gauge
Ok, I am tryig to fit a boost gauge to check boost pressure on my td. Does anyone know what hose / pipe to tap into.
I have a boost gauge, and some plastic tubing. Need to check what pipe to tap into so I can get the correct size t piece.
I remember seeing pictures on a website to do this on a 306 td, but cannot find this. It appeared to be a hose or a pipe, that had been cut, and a tpiece fitted, which then reconnected the cut pipe, and the third branched off to the boost guage.
The only other picture / guide is unclear.
After doing this, I will then get derv doctor, to carry out a phase 1 tune.
Any picures would be brilliant.
while supposedly not the best place to get 100% perfectly accurate unwavering boost measurements, unless you've spent £100+ on the guage then the boost compensator pipe (from the top mount intercooler to the fuel pump) is the best place for it! If you bought the guage new then you should have a Tpiece in the fitting kit, and you probably wont need to seal or clip the connecting pipes as you'll have a job getting them on in the first place!
Ideally you want a 2bar/30psi boost guage as a 1bar guage is a little too close to the 0.8/0.9 you should be getting!
what do you know I found a couple, I've left them as they are so here are the links:
http://web.onetel.com/~glynnunn/ebay/pipea.jpg
http://web.onetel.com/~glynnunn/ebay/pipe.jpg
The clear pipe goes off the the gauge
Right, connected the gauge up and with the car at idle I revved the engine up - the gauge went up to about 0.5 bar - is this correct? Or will I see a bigger reading when im out on the road i.e going up a long sweeping bend in 4th at 45 MPH then feel the turbo kick in and watch the gauge go up? I havent got a clue on this one!
