I had to replace the brake discs all round on a 95 1.9TD Xantia at the w/e.
Fronts were nice and easier to do.
Started on the rears and discovered what some may have experienced I am sure, that after putting the new discs on I couldn't get the caliper to mate with the face on the rear arm and line up nicely with the disc! The face that was bolted to the arm had corroded badly and left about a 2mm layer of the alloy attached to the arm (on both rears). I thought bugger, need another caliper (I have a few spare in the shed [;)]) but then looked at the caliper and after close inspection, (the opposite side had a lovely smooth face) I realised that the two halves were identical, as far as my eyes could tell me, and I thought ah ha I'll swap the bleed nipple over with the inlet for the H/pipe and bolt it on.
Well all is well, the brakes work fine (MOT'd this morning Hurrah) so the swap was successful. I hope the halves are identical (if someone knows otherwise please tell me [;)]), if they are its a handy way of getting round a troublesome caliper!
Cheers Adam.
A handy hint - maybe?
