hi peter
thanks for that i did,nt mention on my last write up that i did try with the brown wire disconnected and it still spins at full speed so it does look like the transistor pack is to blame from what you just said but owing to the fact ive cracked the fan in getting out and putting back the transistor pack looks like im going to need a replacment blower motor anyway but one thats guaranteed to work ok it doesn,t look like you can replace the fan as it looks moulded to the motor shaft and ive located one just need to go and get it.
what do you think or is there any way i can salvage my own.
pete......................
xantia td a/c heater blower not working help
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1207
Sounds like a secondhand one would be your best bet. There should be plenty of them about - if you can find a working one! I have managed to get a couple of them for XMs and there getting like hens teeth. If you connect a battery to one and connect the pin with the brown wire to the + connection (red lead) it should run flat out. It sounds from your description to be the same as the XM one.
hi peter
well ive an update on this problem ive been to another scrappy who had a working heater blower motor from another car i did,nt actully see it working becouse the plugs were cut off but he assured me it did anyway he took it out of that car and tried it in mine it did,nt work so he had a later xantia in he was breaking so he pluged it in to that one to show me it worked the original motor worked ok but when he pluged the motor he tried in mine in that car it it did,nt work so he said there might be somthing in my car thats blowing the motors do you think he,s right hope you understand all that
anyway any ideas.
pete...............................
anyway any ideas.
M'mm sounds very strange. The only thing I can suggest is replacing the motor and control panel from the car that you know they work in, there is nothing else in the system. I cant see that anything on the car could damage the motor except possibly having a full 12v on the control lead (brown) this would be switching the transistors hard on (max speed) but I would have thought they could stand that.
hi pete
the scrappy who tried the blower motor on mine said he,s going to try that motor back in the original car on monday if it works in that then ill buy that motor then investigate the problem further but another thing i could try is contact the previous owner and ask him what was happening and why he cut the plugs off in the first place his words when i brought the car was (replace the switch and the aircon will work!?).
pete...................................
