Do these lumps all use the same model starter motor? GSF Part Numer: N90104
I need to change one on a Pug 205 which has a TU3 1360cc engine and I have a spare starter motor from an AX GT, again a TU3 1360cc. These 2 cars share the same engine and I have also seen that a ZX that has the same engine also has the same starter motor.
Sorry for rambling, any help would be much appreciated.
Cheers,
Jason.
1360cc TU Engine Starter Motor
What makes a starter motor unique is it's fitting flange on the clutch bellhousing (and a few other things).
Since the mentioned cars share the same basic engine type & gearbox type - the startermotors are directly interchangeable.
There are loads of different startermotors fittng the same engine - as several manufacturers do these as subcontractors to the car makers. Add to this any major and minor modifications to the startermotors over the years - and you got numerous part/type numbers all fitting these cars.
- Contact:
