I know about the well known brake pedal mod for the Xantia (removing the spring from the spacer/pushrod to improve the feel).
I did this on my Xantia and I love how the brake pedal feels.
The question is, is there a similar mod for a series 2 XM (rhd) because I hate the springy feel of the pedal on mine?
Thanks,
Stuart
2000 Xantia HDI90 LX
1997 XM 2.0i Turbo VSX Automatic
XM Brake Pedal modification?
I'm not sure about the RHD XM, but on my LHD version ('98) the spring arrangement was exactly the same as my old series 1 XM, i.e. same as Xantia. Just pull out the plastic cylinder and remove the spring - you can adjust the height of the pedal by fitting different lengths of tubing instead (12mm dia. copper water pipe or similar).
//NiSk
//NiSk
