Xantia won't come down
Post Reply
Frenchie_SCG
My Cars:
Post by Frenchie_SCG »
Hi all,
I have a problem with nonHA xantia with antisink spere '98. TurboD. The front end of the car doesnt drop at all when set to normal height, it stays on that UP position. I've greased the struts, but the problem still stays. Even overnight, the back end drops , but the front sinks only 2-3 cm.
The car sinks all the way down when i set it to lowest.
Got any advice?
My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars.
x 1206
Post by Peter.N. »
Does it drop when set to the 'low' position?
Frenchie_SCG
My Cars:
It does go all the way down, without sqeaking. It looks like its a bit stiff for the last inch, but it drops almost to the ground.
My Cars: Currently:
x 1206
Post by Peter.N. »
Is it against the bump stops when on normal height i.e. no suspension movement? If so maybe the height adjustment clamp on the anti roll bar has slipped.
JohnT
My Cars:
Post by JohnT »
This is not an answer but this site is very good and may be of value to you in understanding the system,
http://www.tramontana.co.hu/citroen/
Mandrake
My Cars:
x 666
Post by Mandrake »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Frenchie_SCG</i>
Hi all,
Got any advice?
Greasing the struts wont help this problem, it will be something to do with the height corrector control linkages, either a bit seized up and/or out of adjustment.
Does it come up to normal height from right down ? If it doesn't its possible the little plastic balljoint gizmo is snapped as well. (Due to the linkages being seized up)
Unfortunately access around the front height corrector is pretty tight, even with the car on stands. (Which is a MUST for safety)
Good luck.
Regards,
Simon
Frenchie_SCG
My Cars:
Thanks guys,
I'll take it to the specialist then.
Cheers!!
Post Reply
