Xantia fans working overtime!
The cooling fans on my P reg Xantia 1.9TD (a taxi working a 12 hour shift) seem to be on all day! During the recent hot spell they have been running at the higher speed about 50% of the time and at the lower speed, the other 50%. Today has been much cooler, yet they have been running at the lower speed all day; including when I have the ignition switched on but the engine off. The coolant is fully topped-up and the temp gauge never reads above 85 degrees! The top hose is hot and so is the radiator top. Can anyone explain; is this normal or is there likely to be a fault somewhere?
The brown sensor on the thermostat housing controls the fans.
It goes intermittent or loose connector and causes the fans to spin fast.
It can also cause the STOP-overheat warning lights to come on.
When the air conditioner is close to overload, it will also switch the fans to fast speed.
Also check the earthings under the battery for corrosion.
The fan control box...Bitron...is earthed under the battery.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ktaylor21662</i>
Terry - can you discribe to me where I can find the two 40 amp fuses you mentioned in a previous posting. Thanks, Kevin.
Kevin,
The 2 fuses are mounted to the inside of the passenger side guard, just near the black fuse box.
That's for a Xantia 2 litre 8 valve petrol.
Looking in picture book to see if diesel is different.
Back soon.
Kevin,
Back soon.
Can't find them where you indicated! I'm looking at some pictures myself. Is your under bonnet fuse box of the ridged type (looks similar to the moulding of the air filter housing) as mine is a smaller smooth sided moulding with a separate "box" for the higher amperage fuses. The owners manual does not indicate what these are for; but two, E and F, are 40 amps and next to each other. Could these be them? I'm looking at the wiring diagrams in a Haynes manual to see if they shed any light. Kevin.
Kevin,
Yes, it must be them...40A large fuses.
There are many variations of layout.
Kevin,
