2.1TD g/box - repair or replace?
- My Cars: C5 2.2 VTR + Nav 173
Mazda 6 2.2 Sports Nav Estate
Jaguar 3.8 MkII 1961
Ex 2007 C5 2.2 Estate
Ex 2003 C5 2.2 Estate
Ex Xantia 2.1 TD Exclusive
Ex BX 1.7 DTR
Ex BX 1.9 TRS - x 1
At some point I'm going to need to replace the clutch. Whilst the g/box is out, I have thought of replacing the input shaft bearing as the whine it makes is getting somewhat intrusive. The whine is present in all gears and in neutral, rising and falling with engine speed. Becomes more obvious as the unit warms up. Not noticeable at motorway speeds in fifth.
Assuming my diagnosis is correct, is it a relatively straight forward job? I've always shied away from gearboxes (apart from rebuilding the one in my old Vitesse - I don't think it helped[:)]) but am reasonably competent with mechanicals generally.
The alternative is to find a good replacement - might be easier said than done.
Any ideas?
Any ideas?
- My Cars: C5 X7 2.7 hdi
Past cars
Activa, silver MK1 (221bhp stock) stripped out with twin sparcos Evo seats. 95
Activa, light met red MK1 98
Activa, dark met red MK1 98
Activa, dark met blue MK1 (202bhp stock) 96
Xantia exclusive V6 auto 3l 98
Xantia 2l 8v auto
BX 4x4 GTi dark met silver
BX 4x4 GTi white
BX GTi 16v white fibre bumpers
BX GTi 16v black fibre bumpers
BX GTi 16v hurricane (doa)
BX DTR estate
Ex BX 1.7 DTR
Ex BX 1.9 TRS - x 1
Looks like I'll be replacing the bearing then. I am guessing that Haynes will be utterly useless. There was mention in this forum last year of a much better manual, but I don't recall the name. Or does anyone know of any links that will give the inside info on dismantling/reassembley with all clearances etc?
You are obviously competent at what you are considering, rebuilding the gearbox? The technology has not changed much since your Vitesse. I suggest that if the main roller bearing is the cause then this will be available as a non citroen part ( Timkens etc?). Perhaps you will let us have a detailed post on your adventure if you undertake the repair? Best of luck.
I only did a gearbox once, new synchro on 2nd in a BL gears-in-sump 5 speeder. It wasn't particularly difficult but fiddly and time consuming- Haynes manuals had exploded gearbox diagrams then, and also info on gaps and torques etc, but it was hard to source the bits, and I don't think I would do it again unless there was no alternative!
Input bearings normally rumble rather than whine-are you certain thats what it is?
Isn't the clutch on the Xantia 2.1 TD of the pull type rather than the conventional push type? If this is the case it is more likely that it's the release assembly that is whining rather than the input shaft bearing. I've definitly had this sort of noise from the pull-clutch on my 2.5 TD XM when the clutch was knackered.
//NiSk
//NiSk
Ex BX 1.7 DTR
Ex BX 1.9 TRS - x 1
Thanks for the input guys. JohnT, I agree - very hard to get them back together properly. I've watched someone who knew what they were doing and they made it look easy. Part of the trick with most things is knowing what feels right, as much as what your instruments say.
I hadn't thought of the release bearing - but is the bearing on this setup constantly engaged? In my experience, release bearings either rattle (proven by lightly touching the clutch pedal to exert some load), or squeal when engaged. However, it is true that g/box bearings usually rumble, or produce a 'rushing' noise which vanishes on engaging the clutch.
When the engine/box unit is cold, there is no appreciable noise. After a few miles, the whine becomes more evident increasing to max as the oil temp rises (VSX model - I'd prefer a pressure guage but, hey...). Revving the engine in neutral creates the same symptom as having the box engaged. Hence my focus on the input shaft. It could, of course, be something on the engine itself, but I can't imagine what.
As and when I take on the challenge, I'll keep you posted.
- fastandfurryous
- Location: On the road, travelling at high speed. Meep Meep.
- x 4
Here's a thought. It could possibly be the idler bearing in 5th gear (between the gear and the shaft). This does not rotate when 5th is selected, and so could be the bearing that is making noise. If so, then that's a whole lotta work to change, and getting a PSA gearbox back together is indeed an utter utter nightmare. The gears themselves aren't the problem, it's the selector mechanism.
I've had several Land-Rover gearboxes apart to their component pieces, and rebuilt them. Also a couple of VW Beetle boxes apart, so I'd like to think I have a fair idea of how to put a gearbox together, but having pulled a BE box apart, you need 5 hands and 23 fingers to get it all back together. Not fun at all.
To be honest, you're probably better off getting a 'box from a scrappers. If it's a decent scrappie, they usually offer 1-3 month warranties with their major parts, so at least if it turns out to be a duff one you can take it back or get your money back.
Ex BX 1.7 DTR
Ex BX 1.9 TRS - x 1
The idler gear sounds like the sort of thing that would produce the symptoms. I'll have to do a road test later this week and see if engaging fifth always reduces the noise, irrespective of roadspeed. It that is so, I'll start looking for a price on a replacement 'box, to get a feel for the options. Are the 'boxes from the XM TD12 interchangeable with the Xantia?
First - Its full of oil isn't it?
secondly - many people have obtained very good results with Slick 50 and other additives. There are probably some posts on the subject.
Much easier and cheaper than a rebuild.
http://www.andyspares.com/discussionfor ... IC_ID=1474
Jeremy
Jeremy
Ex BX 1.7 DTR
Ex BX 1.9 TRS - x 1
Aha! Jeremy, you clearly know me. I had already bought some Molyslip some while ago and intended to see if liquid engineering would buy some time. But have you seen the filler plug on this 'box??? It's in about the most dia-bleeding-bolical place it could be! I sometimes think the French have never forgiven the English for having a bigger empire and they inflict Citroens on us in revenge[}:)]. I'll try again this weekend, after the Lions beat the All Hacks (and that's from a born and bred Kiwi! Super 12 nonsense - if you don't want to contest the scrum, go and play League[;)]) by running a tube from the filler up through the engine bay.
Ciao.
Ciao.
