Xantia clutch change using two jacks - possible?
I am no hero but at 60 years old I did it with a trolley jack without many problems. What I do suggest is that you withdraw the gearbox but let it down as little as possible. I then worked within the bell housing area to install the new clutch set. Thus it went back in OK but I did have to persuade it with me lying down on my back, and pushed it in to postion with my feet and waggling it at the same time.Best of luck!
- Contact:
Hi Guys,
not many of you are in my area, but anyone around Ballarat is welcome to borrow my engine crane for a weekend if they need it. It's only a cheapie, but a 2ton engine crane makes life sooooooo easy.
Would you believe since I was 16 I've probably averaged pulling a motor out of a car per year. About 4years ago I swore I'd never do it again without an engine crane. So I went and bought an engine crane ........... I've never needed it since [:(!]...... Haven't used it since the day I got it [V] Though lots of friends and relatives have used it.
Now with the CX & BX both having dead clutches it's going to finally pay for itself [:D]
seeya,
Shane L.
seeya,
Shane L.
Hi Phil
Did you manage to do clutch replacement with trolley jack and axle stands ? Just a bit curious as my clutch is heavy (clip broke few montgs ago - running on new clip) and would have given it a try if it is doable for someone with average diy skills (i did change timing belt on this car) !
All i have access to is trolley jack and 4 axle stands.
best
best
Could anyone kindly confirm the size of hex bit required for removing transmission/engine bolts (for Xantia 1.9 TD SX - 1994 model). I saw someone mentioning this as 7 mm or 8 mm. This is so that i can get all the tools needed in advance. I am assuming that other than this and a standard tool box, i would require 35 mm hub socket and torque qrench. help pls !
