Getting more convinced the rear arm bearings are shot on the xant (very creaky)
Anybody tackled this job? would it be worth just replacing just the roller bearings (not the cups) as there isn't a massive amount of lean yet.
Xantia rear arm bearings
The rear arm repair kit N42358 contains all the bits you need removing - to access the bearings.
Would be false economy replacing the bearings only.
Worst part of the job is removing the inner bearing races. Exactly this has forced many a handy owner to leave the job at their dealer.
The rep. kit is listed for BX - but is the same for Xantia.
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by AndersDK</i>
Unless it's the estate - in which case you need different bearings.
Hi, did mine a couple of months ago " on the drive" with the arm held in a workmate. Once I had removed the plastic inner sleeve by chiseling it into two halves with a ground down old screwdriver, then a lip of between one and two mm is revealed of the inner race, which was sufficient to allow me to tap out the inner races with a long thin chisel from the opposite end. This was in fact the most difficult part of the whole job, apart from fitting the replacement plastic sleeve. You won't need to remove the hub, and the brake caliper can be simply hung up out of the way with a bungee. P.s. It's my understanding that the whole kit of parts should be used for a proper fit when you come to refit the arm to the subframe!!
If I can do it then almost anyone can I'm sure.. Everything is still working ok, but I still don't know if I set the preload on the bearings correctly ( there must be someone here who knows how to do it!) -93 tdsx hatchback by the way
mpr1956,
To set the pre-load is fairly simple.
It's done using the supplied thrusts and basically means that when fully tightened, the bolt is fitted through and the arm will need to be pulled down using the smallest amount of effort. If it just drops under its own weight it's too loose and if you need to use pressure, it's too tight.
Alan S
Alan S
- My Cars: C5 X7 2.7 hdi
Past cars
Activa, silver MK1 (221bhp stock) stripped out with twin sparcos Evo seats. 95
Activa, light met red MK1 98
Activa, dark met red MK1 98
Activa, dark met blue MK1 (202bhp stock) 96
Xantia exclusive V6 auto 3l 98
Xantia 2l 8v auto
BX 4x4 GTi dark met silver
BX 4x4 GTi white
BX GTi 16v white fibre bumpers
BX GTi 16v black fibre bumpers
BX GTi 16v hurricane (doa)
BX DTR estate
if you have a welder the best way to get the bearings out is to weld around the inside of the old one then tap the arm and they will fall out. (welding them makes them shrink (after they have cooled). When i say the best way i mean unless some one else has a way to get them out in under 60 seconds with out breaking a swet then it is.
Andy
Andy
Thanks Alan... There were numerous references to setting the preload on here, but I could find no specific info. If I have to do them again I'll know how!!.
P. Rear arm bearings aren't as difficult as you might think, and I was amazed at the difference in the ride quality -well worth an afternoons work. ( you might also have to budget for having the tracking adjusted afterwards... but my bearings must have been shot for a while.. I don't think MOT checks pick them up )
