apologies, yes I know there have been numerous takes on the problems you can have with the remote central locking/alarm on the ZX, but here's mine. The CL has recently started to ignore me ! ie when clicking the blipper - the indicators flash to show the immobiliser/alarm is set but the doors don't lock. I have sprayed liberally with WD40 into all the locks, but to no avail. When you click the blipper, or lock/unlock the driver's door - you can hear the clicking of what I presume is a relay under the dash. If I fiddle with the buttons on the doors from inside, eventually the CL starts to work again - but then stops working just as easily !
I suspect that what I have is a sticky lock on one of the doors and I will have to remove the door card to get to it. Am I correct or barking up the wrong tree ? If I am right, i there any way to determine which door is causing the problem so I don't have to strip the lot.
Thanks in advance.
Duncan
Central Locking ZX
Blimey what a pharse ! It turned out to be the control unit jobbie under the dash that was not seating correctly ! Found this out only after having stripped both rear doors and lubed the locks. And then - guess what - job done, happy, slams the door with smug grin [:D] - and F$%^ I've locked the keys in the car ! [:(]- It's a 5 door. Yes, I have a spare key, but where is it ?
I am currently revamping my kitchen so things are everywhere and the spare citroen key has a habit of falling of the rack - great. I look - and it's not there ! [:0] Despair - brick ? Bit of bendy plastic ? coathanger bent skillfully ? Not a chance. Then I find the little swine !
Big phew ! [:D]
another 1/2 hour job that took 2 hours and took 2 years off my life !
Big phew ! [:D]
