Xantia Brakes
Xantia Brakes
Anyone want to take a shot at this? M reg Xantia LX owned it for 2 days. When I brake as the car slows to a final stop I get a rubbing feeling from the brakes, but even when the car is stationary and I depress the brake I can feel this rubbing. Any quick ideas? also while I am here, what is the normal running temp for a xantia? is 90 ok??
Not quite sure whats happening from your description but as you say it happens when stationary I suppose its got to be pedal and the connecting spring between the pedal and the brake valve.
Otherwise could it be the sound of bubbles in the LHM rushing through the valve? In which case you may be able to eliminate it by 'Citroebics' - raising and dropping the car on its suspension a few times to circulate fluid. - Good idea to do it occasionally anyway as it keeps everything moving and expells any gas that has leaked from the spheres.
Make sure your LHM level is correct - check with the suspension on full height.
Jeremy
Jeremy
Regulators seldom give trouble but are often blamed. If it still ticks too fast (less than about 30 secs with a new accumulator) you can generally cure it by re-seating the non-return valve, an operation that will probably cost you nothing! (You may even be able to do it with the regulator in place!)
A test for the accumulator is to raise the car fully and see if the ticking rate decreases - Height correctors open, suspension spheres function like 4 accumulators!
Jeremy
Jeremy
Jeremy, I am afraid the thread is getting a little out of my league. I tried the "citrobics" and it hasnt changed anything. On the lowest setting the rubbing stopped, back up to normal height, and it baaaccck! Is it dangerous for me to keep driving it like this? Or should I plan on taking a day off and getting a mechanic to take a look?
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ljaw2002uk</i>
Also I know this sounds dumb - how to I check my LHM level? [:I][:I]
You should have a sight dome on the top of your reservoir. The disc should be between the two red lines when the suspension is on high. OR dip your longest finger in the reservoir. You should just be able to reach the surface of the LHM.
