How to handle the rust?
I've managed to get an SM with the chassis really rusty. You can see the road from inside the car! Main struct of the chassis is also falling apart. [:(] You can't touch it with a finger! [xx(]
What techniques do you recommend to transform it into a new car?
Can you weld? If not, get yourself on a welding and metalworking course and buy a MIG- I learned the hard way 20 odd yrs ago by blowing holes in lots of rusty BL cars, courses weren't really available then as home welding wasn't a common pastime before the classic car boom. A welding course would have made it all so much easier!!!
As well as bxbodger's advice I'd say get a number of books and articles from the restoration mags to see how they tackle various problems. Little is impossible - it just takes loads of time.
A problem you will have is that you can't imitate shaped sections or obtain anything similar. As a matter of interest the side members of a land Rover chassis up to the introduction of the 90 / 110 was simply made up of 4 pieces of 14 gauge (2mm) steel plate welded into a rectangle - no pressings there. OK some of the cross memebers were folded but the main side rails were just welded flat sheet.
This means that you may well be able to make up sections from plate.
2 other points - the first is accuracy - in cutting, bending and fitting prior to welding. Errors build up and become a problem as you'll suddenly find something later won't fit or look right.
The other point is make sure the thing doesn't distort. If you are chopping bits out of chassis the car may bend. if you remove the body it may loose its shape. Many people add re-inforcement while doing the job by for example welding angle iron braces accross door to prevent movement while working on sills.
jeremy
jeremy
- My Cars: C5 X7 2.7 hdi
Past cars
Activa, silver MK1 (221bhp stock) stripped out with twin sparcos Evo seats. 95
Activa, light met red MK1 98
Activa, dark met red MK1 98
Activa, dark met blue MK1 (202bhp stock) 96
Xantia exclusive V6 auto 3l 98
Xantia 2l 8v auto
BX 4x4 GTi dark met silver
BX 4x4 GTi white
BX GTi 16v white fibre bumpers
BX GTi 16v black fibre bumpers
BX GTi 16v hurricane (doa)
BX DTR estate
I'd recomend looking at some of the kit car books that are avalable as they will help you with consepts of keeping the car in shape when welding and also be a guide to what you should and shouldnt do and processes you can use. there is also a locost yahoo group which has some amazing documents.
hayens also do a restoration book which is a good place to start (its one of the only haynes books i've read from cover to cover).
Andy
Andy
http://www.citroensm.net/
This should help you find somebody in the know about the SM. There were several at Classic Cars Live a couple of weeks ago, link to Pictures in General Chat.
With so many SM adverts, you had to pick a rotten one...or is this an April's fools joke, mate?
Tell you what, how about a trip this weekend to the Motorclássico exposition on FIL? Plenty of good chaps to give a hand (and a spare or 2...). Oh, i saw a CX for sale there, it's a white break (like my C5...)
Take care!
PS: if you do decide to go to the exibition, send me a mail. I'm going back there tomorrow [:D]
Take care!
From the SM, sell everything except the engine and box. Buy a CX with the proceeds. Sell the CX engine and box.[:)]
By the Way, congratulations on finding an SM. If you can be realistic about the time and effort, anything is possible; cars are cheap in the states; cheaper still with blown/ removed engines. If you have the space, use the one you have as a source of parts for a better shell and recondition as much as you can while you are waiting for a good car that is being scrapped because somebody blew it up and cannot afford a new engine. That might well entail saving up quite a lot of money but it is the quickest and cheapest way of turning what you have into a decent SM.
I'd endorse Tom's suggestion there.
The SM appears to be the Citroen that was the biggest seller over there (USA) and in the past I have seen ads from owners almost giving them away. In fact a couple of years ago, one guy was trying to quit all his parts and cars literally for scrap metal price because he reckoned that was exactly what he was intending doing with what didn't sell.
An SM with a blown motor (common for the ones not modified) would possibly have an almost rust free body if it were a Californian car and doing a mechanical transplant a sight better proposition to trying to sort major rust, particularly structural stuff.
Freight wouldn't necessarily be all that great an expense if you can find a car importer with some spare space in a container as often they let this go at "backloading" rates.
Alan S
Alan S
