I finally got my interior temp sensor out of my xantia to clean the fan as it hasnt been working for a while and the temperature has been all over the place because of it,
I cleaned it all up and put it back and it still wasnt working, just sort of wobbling back and forwards so i took it fully apart and it turns out that it is actually using a primitive stepper motor (4 pole) to keep it at a constant speed but sadly one of the 2 coils has blown and that it why it cant spin
So now i need a replacement and wondered if anyone had one laying around i could buy off them?,
I have currently just dangled the thermistor out of the dash which i was happy with as it will also act as a sun sensor like the XM has and boost the aircon when the sun comes out, but sadly the wife thinks its an eyesore and is making me get a proper sensor assembly
Anyone selling a temp sensor for a Xantia cheap ?
'13 3008 1.6 HDi GripControl - x 994
I've got one in the same state, which you can have for the cost of the postage if you think you could build one out of two? I haven't investigated the cost new from Citroen, but imagine not that expensive as they don't seem to last very long, so must be replaced frequently! I fitted a second hand one that is a bit noisy, but at least the climate control actual does control at the moment!
Thanks for the offer richard, but i have investigated it a bit more and it is the actual chip that has failed on part of its output, so having another one with a failed chip too wouldnt make 1 good one, thanks anyway though,
I have dangled the thermistor about 3 inches out of the dash on its wires and the climate control works really well now, better than it ever has so i'm not in too much of a rush to get one, i will wait till someone is breaking a xantia
