Hi Everyone
I have LHM fluid leaking from the bottom of the regulator. I assume its the regulator, the Accumulator is attached to it. The fluid is coming from the joint between the regulator and the bolted on bit at the bottom with a pipe coming out of it. Does anyone know what this part is called and whether I can get a gasket for it?
I need to get a new seal for the accumulator. When i renew this, is it possible to unscew the bit of the regulator as well?
Cheers
Andy
Xantia 1.9TD (1995)
Regulator
