2000 MY (W reg) Xantia HDi continually blowing fuse 12 (passenger compartment fusebox).
Fuse 12 covers instruments, brake lights, reversing lights & air con according to haynes book of lies)Reversing lights still working.
Seems like direct short somewhere.
Any suggestions would be greatly appreciated.
Johnny
Xantia HDi wiring
According to my data, the HDi fuse 12 is for the AC master switch and the AC control module. Other Xantia models use the fuse for the AC compressor clutch relay. It should be a 20 amp fuse and if the fuse layout looks like the one in the picture then there is probably an element of truth in it. If so, it is most likely an AC problem.
