Hi all,
I have noticed that I have LHM leaking from a pipe which runs out of the right hand side of the front accumilator sphere (or there abouts). The thing is that checking the reservoir, there is not too much LHM left but the display on top of it is stuck at the very top (indicating that it's full). The dash warning light is obviously run off this top hat indicator as there are two electrical wires connected to it and because the hat is stuck, there is no warning on the dash that the LHM is low.
For my own piece of mind I would like to get the indicator unstuck and reading correctly. Is this easy. Any info on doing this would be very welcome.
Oh, and can anyone recommend a Cit mechanic not too far from South London to get the leak fixed.
I'd like to do it myself if it isn't too difficult. Will try to add photo of suspect pipe.
Cheers
Xantia LHM Indicator
hi ive just had the same problem on my 20i lx xantia it turned out to be the front accumulator which i had to replace its accully leaking from the valve where the pipe your talking about leads to mine used to leave a pool of lhm fluid on the floor before i fixed it. you have to replace the complete unit becouse if you try and replace the valve on its own you,ll have more problems i picked a second hand one up from a reliabile Citroen breakers in my area for £35 so they,re not that dear to replace and it took me an afternoon to change it and its fine now if you need to know to know anymore about replacing it just let me know and ill give you all the advice you need to do the job
About the leak : try if the pipe union in question can be nipped up.
The reservoir level indicator does not indicate when the reservoir is filled to the top. Approx 2/3 level down, the float will free it's top stuck position, and approx 1/2 reservoir level left the float will activate the warning switch you have noticed.
The correct procedure checking the reservoir level is to set the suspension height to highest position and then check the float indicator is within the 2 red rings.
Meaning : with suspension in low or normal heights, the float WILL (should) be stuck against top.
Overfilling the reservoir has the frightening effect of your mistress or neighbours getting very upset by the messy spillage on the driveway [:p]
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by anno888</i>
When my float got stuck at the top, I drilled a 2mm hole in the crown of the dome, pushed the float downwards and sealed the hole with a tiny blob of blue-tac.
2018 Citroen C4-B7
- Contact:
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by np</i>
JohnD,is that little trick still working?
Must be three years ago that I drilled and pushed - it's been fine ever since. Even had a change of LHM since then.
when i first got my car the reservoir was full to bursting & float obviously buried in the top of the dome as far as iknow its never been down & i still get a little pool of fluid on outside of res which suggests to me theres probably still a bit too much in there but the suspension works perfectly so i aint going to upset it to satisfy that little spark of something thats in all of us wich makes us want to see that float change position like it says it should in the manual:)
