Well I couldn't swear to it, but I am fairly sure that releasing the pressure in the system as per normally described here will do the job for you. I can find nothing to suggest otherwise. The worst can happen is if you find there is still pressure in the hoses - but I can't see how that would happen if you follow the instructions...
PJ
Activa leaking LHM...
The joint I refered to on the BX strut is simply a hole in the outer casing against which a small rubber adaptor with the hoses attached is clamped by a clip going round the strut. As there is no screw or anything, simply the force exerted by the clamp which doesn't cover the whole of the adaptor, excess flow allows a pressure to develop and the rubber adaptor lifts allowing leakage.
From the previous thread I recall that there was a similar hole with an adaptor pressed against it on the Xantia Activa strut. I've never seen one and am therefore reliant on someone elses description.
Jeremy
Jeremy
- Panjandrum
Unlike your conventional strut, the activa rams have to cope with high pressure to either side. Sometimes they's pushing up, sometime's they's pulling down. Hence the TWO high-pressure-capable connections to the base of the ram.
Somewhere in this story is the clue to the Activa's traffic-light dance or Activa Shimmy - when it decides it needs to pump up the front right corner for reasons entirely of its own.
- Panjandrum
It sounds right for a Cit dealer!! A bit over 4 years ago rear ram and some bushes would have cost me £370 at dealer - but were still under warranty. But it really seems extortionate. You can see the thing sitting there, easily accessible. You would think it's no harder to replace than a sphere - but of course that's only from looking at it.
Did you try searching here?
PJ
PJ
